12-10-2020 02:40 AM
Can you give me an example of a csv template to use the import csv feature on L2 Access Control in vSZ?
Thanks,
04-08-2021 12:02 PM
This would be very helpful to me as well. I have not been able to find this documented.
04-08-2021 12:32 PM
After poking around in the interface a bit more, I found that I could download a sample from the "Import CSV" button if I carefully click on the down arrow on the button. Miss it slightly and the button executes instead. The format is a single column with the MAC address(es) to be imported but it MUST have the column header "mac" on the first row.
