Add T310 to Ruckus Virtual SmartZone Controller
luke_blundell
I am trying to convert the Ruckus T310 AP to join our managed smartzone controller. I have done this for our R310/R510 numerous times withou any issues but the putty commands don't appear to be the same or work.
I feel it needs a particular software install on it to work but I can't seem to find it or if its even possible!
Any help would be greatly appreciated.
16 REPLIES 16
@ratnadeep_nandi
I am getting this error with that software though.
Image_ images_messages_619660e137295e5a876859cd_397115a7f2e166c5959d82bbdf173159_error-d707ccd4-e2c2-425a-879d-e90fda26a100-328373979.JPG
@luke_blundell
Hi Luke,
Are you trying with 200.11.x version? Please upgrade the AP to 104.x version.
Download the firmware from the below URL:
https://support.ruckuswireless.com/software?filter=64#sort=relevancy&f:@source=[Software%20Downloads...
Ratnadeep
Yes I am - I have tried all the versions from T310C D N S and none are working for me.
@luke_blundell
If I am correct this Master AP T310 has another Member t300 AP connected to it ? If yes can you follow below :
1) Disable member AP T300 (shut that port)
2) Perform F/D on T310 AP and upload standlaone image again.
Let us know how that went.
Best Regards
Vineet
I have upgraded it finally but the putty commands are still not working.
Please see attached.
Image_ images_messages_619672e114a66e5df74fe8d7_49eef8ceee00e1bc8a7f286dd815a428_error2-75a8cf0a-27f3-403a-a734-ef0a981e43c9-1592513277.JPG
