04-16-2024 08:04 AM
Hello friends, a question, I have a sz300, is there a way to reschedule an AP restart every Sunday? In the scripts part I see that the "reboot" command is not allowed. Is there any way I can do it? I have a case where users do not see band 2.4 but when they restart the Ap they connect without problem.
04-23-2024 06:33 AM - edited 04-23-2024 06:34 AM
Hi Luis,
Even though there is an alert indicating that the reboot command is not allowed, you can still run it, and the system will prompt you to confirm your action.
However, if you are rebooting to address a recurring issue with the 2.4GHz band, I strongly recommend upgrading both the SZ and APs to the latest recommended versions. After the upgrade, monitor the system to see if the issue persists.
