11-06-2023 09:22 AM
Dear Ruckus,
I am using R650 and i am getting ping when directly connected to the Access points but after adding in vsz not getting the ap ping.
please give a appropriate solution i have to monitor it with nms
Thanks & Regards
Mohd Faijan
11-06-2023 11:12 AM
Hi Faijan,
When you say directly connected are you saying it on standalone or you are connected to SSID on that AP. Also, can you let me know what type of SSID are you using to ping the AP when connected to vSZ. Are you able to ping the AP from the wired network?
Rao
11-20-2023 11:24 PM
Dear Rao,
directly connected means AP is directly connected with my pc then we are getting ping of AP, after adding in vsz afterthen we connect to the ssid's then my pc is not getting ping of the AP
11-21-2023 08:49 AM
If I understand correctly, the AP shows 'online' status in the vSZ, also, from the vSZ or from the wired network the AP responds to ping.
The problem is only when trying to ping the AP from a wireless client?
In that case please let us know the VLAN of those SSIDs and also the VLAN of the AP.
