09-09-2024 06:56 AM
After power outage experiencing poor/intermittent internet connectivity. Suspecting the switch is running routing code as documented here:
Following instructions to locate the switch IP and am unable to locate the IP as documented here:
09-20-2024 10:20 AM
Hi @BT
Greetings of the day!!!
Thank you for sharing the requested information on an private chat.
Based on the troubleshooting done, your ICX-7150-C12P Switch is not working with console cable to access CLI and not getting IP address assigned from the ISP (Internet Service Provider's) Router. Checked with multiple troubleshooting steps. However, the failure persists. This Switch unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
Thank you again. We really appreciate your patience and understanding.
09-09-2024 07:10 AM
Hi @BT
Based on the information provided, it appears that you are encountering Routing code issues with your RUCKUS ICX-7150-C12P Switch and are unable to find the IP address to fix the same.
If you are unable to get the IP address of the Switch, please try getting console access to the Switch and help me with the command outputs I shared previously.
Here is a guide on how to access the Switch via console (cable access between your PC to the ICX 7150-C12P) in this case we need a USB type C to USB standard OR Console cable Rj45 to USB (Any one cable- please refer the guide)
How to console in the ICX-7150-C12P:
Once you are logged in to the ICX-7150-C12P please follow and perform the commands from the SPR article.
09-09-2024 07:25 AM
I connected to the switch via USB. I'm unable to login with any user name and password. Even after factory resetting the switch I cannot login with the factory default username and password.
09-09-2024 07:54 AM
Hi @BT
While you have the laptop connected to the Switch with a console USB cable and the CLI screen up it asking a username/password, reboot (unplug and plug from the power outlet), and follow the video below.
https://www.youtube.com/watch?v=0ynKwSTpd_A
Once you have successfully recovered the switch password, use the following commands to either modify the existing password or create a new username and password:
configure terminal
device(config)# username super password pass
In this example, the username is ‘super’ and the password is ‘pass’.
To ensure proper authentication, execute the following commands:
device(config)# crypto key generate rsa
device(config)# aaa authentication login default local
device(config)# aaa authentication web-server default local
09-09-2024 04:51 PM - edited 09-09-2024 04:59 PM
Thank you for the instructions, Imran. I was able to get to the boot menu, enter 'no password' and then reboot the device. However, I'm still being prompted for login.
I'm also seeing errors in the boot process
