solid AMBER (system) and GREEN (power) lights
manny_ajvalia
My switch is showing solid amber light for system and solid green for power.
My Access points are not receiving power.
Please assist.
Thank you 🙂
8 REPLIES 8
pinky_ruckus
Hello @manny_ajvalia ,
From the case description, I understand that the status lights on the Switch is Amber and the PWR light is Green, which means that the Switch is stuck in a boot mode
Please follow the below RUCKUS Lennar Knowledge base self-help article which will help you to fix the issue when the Switch is in boot mode.
https://community.ruckuswireless.com/t5/RUCKUS-Lennar-Support-Knowledge/Fixing-RUCKUS-Switch-with-an...
Please follow the process as explained in the article and let me know if you have any queries in this regard.
Hello:
The video was very informative.  However can you show/explain how and where to connect the USB-C and Network cables on the switch?
Thanks.
From the response, I understand that you need assistance in connecting the ethernet cable and the C-type cable.
Please refer to the below picture to understand the connection between the cables.
A console cable connected between your Computer to the ICX 7150 Switch Type-C USB console port.
Note: The cable type will be USB to type C, where the USB it’s going to your computer and the type C to the Type C connection in your switch, is the port number#1 in the next guide.
Port-side view
https://docs.commscope.com/bundle/icx7150-installguide/page/GUID-98DBADCF-277F-4450-8A0B-58A4F916179...
 Ethernet cable connected between the Out-of-band management port in the Switch to your computer Ethernet port.
Please use this video link for reference:
Please note, we must use ethernet cable (both ends RJ45 plugs) and USB to type C cable both together as described in steps 2 & 3 in the guide link.
Thank you for the detailed explanation.
QUESTIONS: for my switch:  ICX 7150-C12P,
1. what is the "4. Slot 1 (10/100/1000 Mbps RJ-45 downlink) ports" used for?
2. what is the "Slot 2 (10/100/1000 Mbps RJ-45 uplink) ports (half-duplex is not supported on these ports)" used for?
3. what is the "Slot 3 (SFP+ uplink or stacking ports)"
4. Which ports should I connect my 2 two APs in?
Thank you.
