issues with access points wifi connection
ssgrandam
after we switched internet provider only one of two access point shows up on available Wifi and only 5G. there used to be upstairs & downstairs wifi login with both having 5g & 2.4g. without the 2.4 my thermostats are not connecting to wifi. upstairs access point has 5G, 2.4G, & PWR green light. downstairs has 5G, 2.4G, CTL, & PWR green light. what need to be done to return it to how it was?
19 REPLIES 19
Hi @ssgrandam
Please note that there will be a single Wi-Fi network broadcast by all RUCKUS Access Points. Client devices will automatically connect to the nearest access point based on signal strength.
Please confirm if this behavior is what you are observing on your devices.
All lights are green. Only 1 CTL light on green. Not sure if both access points need it on. I remember there used 2 wifi networks. Still can't connect my upstairs thermostat.
Hi @ssgrandam
CTL light on only 1 Access Point is a normal behavior. Only Master AP will have it.
To check and help you troubleshoot further please provide a photo showing the status of the lights and the full switch panel with cable connections to the switch ports.
Hi @ssgrandam
Thank you.
Hi @ssgrandam
Thank you.
