01-23-2026 11:41 AM
Issue Description: Following a power disruption, my Ruckus switch is having connection issues with certain websites. Historically, the device exhibited "flaky" behavior after reboots, usually requiring multiple power cycles of both the router and switch to recover. However, the switch is currently failing to route traffic or allow management access.
Current Status:
Requested Assistance:
01-23-2026 05:13 PM
Thanks Imran!
01-23-2026 11:56 AM
Hi @mfalam84
Based on the information provided, it appears that you are encountering intermittent internet connectivity.
This issue is typically caused by a Routing Code (SPR) problem, often triggered by a power outage.
Please refer to the RUCKUS Lennar Knowledge Base self-help article below to review the steps for checking and troubleshooting this issue:
Additionally, please check default username passwords to login:
Please let me know if you need assistance at any step during the process.
01-23-2026 05:13 PM
Thanks Imran!
01-26-2026 04:35 AM
Hi @mfalam84
Thank you for the response and I trust this message finds you well.
Thank you.
01-28-2026 04:26 AM
Hi @mfalam84
Thank you.
