cx7150 switch doesn't work right
wheels4wb
I am hoping you can please help me. I have spent the last three days going through your website trying to figure out was is wrong with my cx7150 to no luck. Please let me explain. two years ago i replace my cx7150, or (RMA) . Another unit was sent out, at that time I couldn't figure how to set it up. so i  never use it. Recently I thought i would try again to set it up, but not able to again. I am disable and i truly having the hardest time with this. I WOULD love to use this system one day. please help.
14 REPLIES 14
Hello @wheels4wb ,
Yes please, I am unable to pull up the switch online, it doesn’t show?
Hello @wheels4wb ,
Please unplug the ethernet cable of the Switch that comes from the ISP (Internet Service Provider’s) Router and plug it back into any other available 1-in-12 ports as highlighted in the below screenshot. Once done, please reboot (unplug and plug from the power outlet)your ISP Router once and once it comes up, check the internet connection stability via RUCKUS.
Hello @wheels4wb ,
Could you please confirm if you have unplugged the ISP cable and plugged in back to one of the 12 ports of the Switch as requested in the previous post?
Hello @wheels4wb ,
