04-17-2024 08:36 AM
Lennar home staus light green standy light green access port no power
04-17-2024 10:42 AM
Hi
Hope you are doing well!!!
I can see there is another post raised by you on the Lennar forum (please refer to the below link). Please follow the same post thread, one of our Engineers, Pinky Rajendran will assist you with the same.
Thank you again for your understanding.
04-17-2024 01:07 PM
Power was turn off for 20 minutes
green power and standby green
access ports no lights at all
no lights were the lan lines connect even after multiple resets lights never came on
04-17-2024 01:49 PM
Hi @Tony
I see from the Picture you shared, that the status of the RUCKUS ICX-7150-C12P Switch seems normal and the issue seems more on the Switch ports which might have gotten into the disabled state.
Please follow the below RUCKUS Lennar Knowledge base self-help article which will help you to check if the PoE is disabled and to fix the issue if they are disabled.
Please follow the process and let me know if you need any help during the process.
