12-28-2022 03:54 PM
Wifi is not showing up after the power outage in my home. The modem lights are not blinking as well.
12-29-2022 04:24 AM
Hi @50509760
Hope you are doing well!
1-On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on?
2-
Best Regards
Fernando Vasquez
01-01-2023 10:54 AM
I see both amber and green on my switch.
01-01-2023 10:56 AM
I see green for power and amber/orange for syst indicator.
01-02-2023 07:21 AM
Hi @50509760
Based on your description, it seems that the Switch (ICX7150 Switch) is stuck in boot mode, so the unit will not pass any kind of traffic, in order to fix the problem, you will have to perform a software recovery which requires, two connections between your ICX to a computer, I am going to advise use a window because the steps are easier, one connection will be the console connection, using a type C/USB cable, where type C cable will be connected to the ICX7150 Switch and the USB to your computer, finally the second connection will be a regular Ethernet cable connected between the computer and the out-of-band management port on your Switch, don't worry because the following guide will explain in detail the step by step.
Note: after fixing the issue of the Switch being stuck in boot mode, please perform an upgrade to the code 08095g UFI and upgrade both partitions with the switching code file named SPS08095gufi.bin, so perform the software recovery using the code 08090k with the upgrade image file named SPS08090k.bin, then when the switch is back to normal upgrade to the file SPS08095gufi.bin in both partitions primary and secondary.
Yarenis Hernández.
Technical Support Engineer | L2 TAC Wired | Lennar Home Community
