08-30-2023 04:59 PM
Hello Ruckus Support,
I hope this email finds you well. I am writing to request immediate assistance with a critical issue I am experiencing with my Ruckus 7150 C120 switch. The system has unexpectedly stopped working, and I am encountering a problem where Power over Ethernet (PoE) is not providing power to the various devices connected to the switch.
Issue Description: Upon attempting to power on the Ruckus 7150 C120 switch, I discovered that it is no longer functioning properly. The PoE feature, which is crucial for powering the connected devices, seems to have failed. None of the devices connected to the switch are receiving power, leading to a disruption in our network infrastructure.
Troubleshooting Steps Taken: In an attempt to resolve the issue, I performed a complete reset of the switch following the manufacturer's guidelines. Unfortunately, this did not result in any improvement, and the problem persists. The switch remains unresponsive, and the PoE functionality remains inactive.
Lennar Homes Support Update: After contacting Ruckus Customer Support (CRS), I was informed that Lennar Homes is no longer supported for direct replacements of devices. I was informed that replacement devices will now be approved by the community manager through a designated forum.
Given the critical nature of the switch issue and the new replacement procedure, I kindly request your prompt attention to the matter. I urgently need a replacement for the faulty Ruckus 7150 C120 switch to restore our network functionality as soon as possible. Please provide guidance on the next steps I should take to initiate the approval process for the replacement device through the designated community manager forum.
I can be reached via email at [email protected]. Thank you for your prompt assistance in resolving this critical matter. I look forward to your swift response.
08-30-2023 05:04 PM
Hi @bdilone
Hope you are doing well!!!
As per the case description, I could understand that your RUCKUS setup is not working, and Access Points do not have power after a power outage.
Apologies, we cannot replace the Switch before trying the troubleshooting steps to resolve it. Warranty is not covered on software issues as it can be fixed by the troubleshooting steps.
On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture and share a picture of the same, showing the light status and the FULL Switch panel cable connections to the Switch ports)
Please let us know the answers to the above query or let us know if you have any queries in this regard.
09-10-2023 04:18 PM
hello,
I have a video performing a factory reset and it doesn't shoe any lights.
09-11-2023 08:52 AM
Hi @bdilone
Please perform the next commands after this step you see in the below screenshot.
Please perform the below commands.
“setenv image_name SPS08090k.bin” (enter the correct image file name)
“update_primary” (upload the image on the primary partition)
“update_secondary” (upload the image on the secondary partition)
*Wait that loads the image and continue with the boot:
“setenv uboot mnz10115.bin” (enter the correct boot file name)
“update_uboot” (upload the boot code)
* Wait that loads the boot and continue with the Final command reset:
“reset” (finally enter reset to reload the unit)
After performing the above commands please check if Switch lights turns green and let me know if you have any queries in this regard.
09-11-2023 09:11 AM
Hi @bdilone
Please follow the steps shared in my previous post and let me know if you have any issues.
