System stopped working, AP was factory reset and it won't broadcast new SSID
FL2CO
I started having issues with my system a few days ago and yesterday it stopped running internet traffic. The SSID was still broadcasting, but it was basically dead for traffic. After powering down, unplugging, and all the usual steps I tried loading the new firmware and that didn't do anything...not sure it completed the update.
My next option was a factory reset so I unplugged all APs except the primary and did a hard reset. That allowed me to connect to the Configure.Me and I went through the whole process and it indicated that it was compelted but the new SSID won't broadcast - it's stuck on the Configure.Me. Any ideas on what I should do, or should I open an RMA on the device? I'm stuck.
Thank you
1 ACCEPTED SOLUTION
Valued Contributor III
Hi @FL2CO
Greetings of the day,
Thanks for your detailed description,
For detailed understanding of the issue please share the image of the switch and the access points showing the LED status and the cable connections.
Also please let us know how many access points are connected to the switch.
5 REPLIES 5
Hi @FL2CO
Apologies for the delayed response.
Please let me know if you have any issues and need any assistance in this regard.
