01-16-2024 11:05 AM - edited 01-16-2024 11:06 AM
Icx7150 switch stuck in router mode. Will not connect access ports. Need a replacement.
01-16-2024 11:34 AM
After booting the ap looks like this
01-16-2024 11:39 AM
Hi @Cg44150
As per the light status of the RUCKUS ICX-7150-C12P Switch and Access points, they seem to be in a normal state.
As you mentioned your Switch may be stuck on the Routing Code due to the power outage.
Please follow the below RUCKUS 'Lennar Home Knowledge Base' self-help guide to get this issue fixed.
Please follow the above guide and let me know if you are stuck at any point during the process.
01-16-2024 11:48 AM
I have already done the above. At first I could not get the up address because I cannot access the switch in the unleash app. Then when I got theIP address I kept getting errors. I am NOT going through that again. And I don’t have a cable to connect directly. I need a new switch please. I will be happy to return the old one.
01-16-2024 11:50 AM
If I just needed those directions I wouldn’t be on here.
01-16-2024 12:31 PM
No response?
