01-16-2024 11:05 AM - edited 01-16-2024 11:06 AM
Icx7150 switch stuck in router mode. Will not connect access ports. Need a replacement.
01-16-2024 11:15 AM
Hi @Cg44150
As per the case description, I understand that your RUCKUS Switch is stuck on Routing code mode.
3. Is your Internet Connection from the Internet Service Provider (ISP) stable and working? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from the Router to a laptop/PC).
Please let me know the answers to ALL the above queries or let me know if you have any queries in this regard.
01-16-2024 11:22 AM
Yes it worked before. Yes there were power outages/serges. The isp connection is fine and works without ruckus system. I have 3 access points connected. Will send pictures as well.
01-16-2024 11:29 AM
Hi @Cg44150
Could you please share the pictures as well?
01-16-2024 11:33 AM
