06-11-2023 07:43 AM
None of the APs (4) are receiving signal from the switch.
06-16-2023 03:05 PM
Hi @Silverbullet
Please try to Access the COM3 and COM4 as Serial Line with Speed 9600. I believe you have tried COM4 once.
Could you please reboot your Switch once and perform the software recovery once again on Putty?
If still you are getting the same result, I request you please download the MobaXterm app similar to Putty and perform the same operation once again there.
Below is the link to download the MobaXterm application:
Mobaxterm: https://mobaxterm.mobatek.net/download-home-edition.html
06-16-2023 03:10 PM
I have tried that as well.. and have also rebooted the ruckus while restarting both putty and Moba. I have to use the com 4 port... com3 will not work... let me launch moba again.
06-16-2023 03:15 PM
06-16-2023 03:28 PM
Hi @Silverbullet
Please also try COM3.
If still it’s not working, please provide a PICTURE and VIDEO following with the process showing all the physical cable connections. (Please refer to the below screenshot)
Please use the below link to upload a VIDEO by following the process with getting an error and showing all cable connections between the Switch and Laptop/PC:
06-16-2023 03:37 PM
Imran: I'm sorry, but I've already tried everything you have asked and more. I've included pictures of everything and I'm still back to where I started; we are going in circles. The device is not responding to anything. It's time to escalate this to the next level.
