09-03-2024 08:50 AM
Switch is an icx 7150-c12p. at the moment no port is providing POE. I have to use an injector to have the Ruckus AP working. I have to restart the switch a lot for maybe a port or 2 to work. Things are working slow as well.
I have things connected to 9 of the ports and only 4 are showing up. Switch says POE is ok but it is not. Temperature is ok. Please see output from switch below. Please let me know what we can do to replace. This switch is broken.
telnet@ICX7150-C12 Switch# show chassis
The stack unit 1 chassis info:
Power supply 1 (AC - PoE) present, status ok
Fanless model
Slot 1 Current Temperature: 70.5 deg-C (Sensor 1), 10.0 deg-C (Sensor 2), 57.2 deg-C (Sensor 3), 52.8 deg-C (Sensor 4)
Slot 2 Current Temperature: NA
Slot 3 Current Temperature: NA
Warning level.......: 100.0 deg-C
Shutdown level......: 109.0 deg-C
Boot Prom MAC : d4c1.9e1e.783b
Management MAC: d4c1.9e1e.783b
Port Link State Dupl Speed Trunk Tag Pvid Pri MAC Name
1/1/1 Down None None None None No 1 0 d4c1.9e1e.783b
1/1/2 Down None None None None No 1 0 d4c1.9e1e.783c
1/1/3 Down None None None None No 1 0 d4c1.9e1e.783d
1/1/4 Down None None None None No 1 0 d4c1.9e1e.783e
1/1/5 Down None None None None No 1 0 d4c1.9e1e.783f
1/1/6 Down None None None None No 1 0 d4c1.9e1e.7840
1/1/7 Down None None None None No 1 0 d4c1.9e1e.7841
1/1/8 Up Forward Full 1G None No 1 0 d4c1.9e1e.7842
1/1/9 Up Forward Full 1G None No 1 0 d4c1.9e1e.7843
1/1/10 Down None None None None No 1 0 d4c1.9e1e.7844
1/1/11 Up Forward Full 1G None No 1 0 d4c1.9e1e.7845
1/1/12 Up Forward Full 100M None No 1 0 d4c1.9e1e.7846
1/2/1 Down None None None None No 1 0 d4c1.9e1e.7848
1/2/2 Down None None None None No 1 0 d4c1.9e1e.7849
1/3/1 Down None None None None No 1 0 d4c1.9e1e.784a
1/3/2 Down None None None None No 1 0 d4c1.9e1e.784b
mgmt1 Down None None None None No None 0 d4c1.9e1e.783b
09-04-2024 08:35 AM
I am not able to replicate the issue to provide a screen shot. When trying to do copy tftp flash 192.168.1.166 SPS08095gufi.bin primary, I kept getting errors. It will start but say that the firmware was not compatible for this hardware or something along those lines. Using the SPS08090kufi.bin seem to work on CLI but I kept following the web GUI steps. Now I have SPS08090kufi.bin, see below. Now that I have the update it seems to want to take the other older firmware upgrades.
I was able to install 08080f but when warm restarted switch was dead. I waited a while but had to do a hard power reset. So, to me the better version is 08090k so far. We will see how this works. So far so good. Thank you for your assistance.
telnet@ICX7150-C12 Switch# sh flash
Stack unit 1:
Compressed Pri Code size = 29360128, Version:08.0.90kT211 (SPS08090k.bin)
Compressed Sec Code size = 28314668, Version:08.0.61aT213 (SPR08061a.bin)
Compressed Pri Boot Code size = 786944, Version:10.1.18T225 (mnz10118)
Compressed Sec Boot Code size = 786944, Version:10.1.10T225 (mnz10110)
Code Flash Free Space = 1224908800
1/1/2 Up Forward Full 100M None No 1 0 d4c1.9e1e.783c
1/1/3 Up Forward Full 1G None No 1 0 d4c1.9e1e.783d
1/1/5 Up Forward Full 100M None No 1 0 d4c1.9e1e.783f
1/1/7 Up Forward Full 1G None No 1 0 d4c1.9e1e.7841
1/1/8 Up Forward Full 100M None No 1 0 d4c1.9e1e.7842
1/1/9 Down None None None None No 1 0 d4c1.9e1e.7843
1/1/10 Up Forward Full 1G None No 1 0 d4c1.9e1e.7844
1/1/11 Down None None None None No 1 0 d4c1.9e1e.7845
1/1/12 Up Forward Full 1G None No 1 0 d4c1.9e1e.7846
1/2/1 Up Forward Full 1G None No 1 0 d4c1.9e1e.7848
09-03-2024 09:21 AM
telnet@ICX7150-C12 Switch#show ip address
IP Address Type Lease Time
192.168.1.92 Dynamic 84188
Current License: 2X1G
8192 KB boot flash memory
2048 MB code flash memory
1024 MB DRAM
STACKID 1 system uptime is 11 day(s) 34 minute(s) 33 second(s)
The system started at 11:40:57 GMT+00 Fri Aug 23 2024
telnet@ICX7150-C12 Switch#show version
Copyright (c) 1996-2017 Brocade Communications Systems, Inc. All rights reserved.
UNIT 1: compiled on Aug 14 2017 at 06:54:44 labeled as SPS08061a
(24723488 bytes) from Primary SPS08061a.bin
SW: Version 08.0.61aT211
Compressed Boot-Monitor Image size = 786944, Version:10.1.10T225 (mnz10110)
Compiled on Sun Jun 25 09:25:15 2017
HW: Stackable ICX7150-C12-POE
Serial #:FEK3212P0SH
1024 MB DRAM
STACKID 1 system uptime is 11 day(s) 34 minute(s) 56 second(s)
--More--, next page: Space, next line: Return key, quit: Control-c
telnet@ICX7150-C12 Switch# show flash
Stack unit 1:
Compressed Pri Code size = 24723488, Version:08.0.61aT211 (SPS08061a.bin)
Code Flash Free Space = 1311776768
telnet@ICX7150-C12 Switch#show interface brief
telnet@ICX7150-C12 Switch# show inline power
Power Capacity: Total is 124000 mWatts. Current Free is 108600 mWatts.
Power Allocations: Requests Honored 9 times
1/1/1 On Off 0 0 n/a n/a 3 main supply voltage low
1/1/2 On Off 0 0 n/a n/a 3 main supply voltage low
1/1/3 On Off 0 0 n/a n/a 3 main supply voltage low
1/1/4 On Off 0 0 n/a n/a 3 main supply voltage low
1/1/5 On Off 0 15400 n/a n/a 3 n/a
1/1/6 On Off 0 0 n/a n/a 3 main supply voltage low
1/1/7 Off Off 0 0 n/a n/a 3 n/a
1/1/8 Off Off 0 0 n/a n/a 3 n/a
1/1/9 Off Off 0 0 n/a n/a 3 n/a
1/1/10 Off Off 0 0 n/a n/a 3 n/a
1/1/11 Off Off 0 0 n/a n/a 3 n/a
1/1/12 Off Off 0 0 n/a n/a 3 n/a
Total 0 15400
Firmware
Version
01.8.7 Build 021
Hardware
Version
V2R2
--More--, next page: Space, next line: Return key, quit: Control-c^C
telnet@ICX7150-C12 Switch#show inline power detail
Power Supply Data On unit 1:
Power Supply Data:
Power Supply #1:
Max Curr: 2.3 Amps
Voltage: 54.0 Volts
Capacity: 124 Watts
PoePower: 124 Watts
POE Details Info. On Unit 1 :
General PoE Data:
Firmware
Version
01.8.7 Build 021
Hardware
Version
V2R2
Cumulative Port State Data:
#Ports #Ports #Ports #Ports #Ports #Ports #Ports
Admin-On Admin-Off Oper-On Oper-Off Off-Denied Off-No-PD Off-Fault
6 6 0 12 0 2 5
Cumulative Port Power Data:
#Ports #Ports #Ports Power Power
Pri: 1 Pri: 2 Pri: 3 Consumption Allocation
0 0 6 0.000 W 15.400 W
09-03-2024 09:40 AM
Hi @ramirezcrisaf
Thank you for your response and the provided update.
Based on the commands you shared, it appears that your RUCKUS ICX-7150-C12P Switch is running an outdated non-UFI 08061a version, which is likely causing the issues you are experiencing.
I recommend upgrading the switch to the recommended version. For detailed instructions on the upgrade process, please refer to the following RUCKUS Lennar Knowledge Base article:
Since you have access to the CLI, I suggest following the 2nd upgrade option outlined in the article.
Please proceed with the upgrade and let me know if you encounter any difficulties during the process.
09-03-2024 09:43 AM
I just warm restarted the switch and took 1 cable outa and connected using an injector to power the device connected to the switch. Now you can see more ports up.
1/1/10 Up Forward Full 100M None No 1 0 d4c1.9e1e.7844
Power Capacity: Total is 124000 mWatts. Current Free is 77800 mWatts.
Power Allocations: Requests Honored 6 times
1/1/1 On On 3200 15400 802.3af Class 3 3 n/a
1/1/2 On On 2500 15400 802.3af n/a 3 n/a
1/1/3 On Off 0 0 n/a n/a 3 n/a
1/1/4 On Off 0 0 n/a n/a 3 n/a
1/1/5 On On 2200 15400 802.3af n/a 3 n/a
1/1/6 On Off 0 0 n/a n/a 3 n/a
09-03-2024 09:50 AM
Well, that outdated firmware maybe an issue, but that doesn't change the fact that multiple ports when I connect POE devices do not power up. Also, per the output I sent before it says low voltage. This looks more like a hardware issue.
09-03-2024 09:52 AM
Hi @ramirezcrisaf
Please upgrade your Switch as described in my previous post. Please note that these issues usually may be due to an older version.
