03-01-2021 02:02 PM
Setting Up New Lennar Home System
Hello experts,
I just moved into a Lennar home with a Ruckus ICX-7150-C12 switch, and three Ruckus R510 WAPs. I have tried following the phone app instructions from this video, and using my laptop and this video, but haven't been successful.
I have ran into several issues along the way (particularly with the phone app), but here's where I am right now:
The thing is that, now the Configure.Me-xxxxxx Wi-Fi network has now disappeared, so I don't have anything to connect to to try to configure things again.
I have fiber internet thru AT&T, so I have an BGW320-505 ONT directly connected to the ICX-7150-C12. If I go to my AT&T network app, I can see the ICX7150-C12-Switch and three Ruckus-Unleashed devices (for the WAPs I presume), so I believe all components are online (not sure this helps with the issue, but I figured I would mention the rest of the setup).
I read in a few places to try to connect my laptop to the ICX7150-C12 directly using an ethernet cable to setup/check the network from there. I tried connecting to one of the PoE ports and access 192.168.0.1, but that didn't work.
Any suggestions on where to go from here would be greatly appreciated.
03-01-2021 06:21 PM
When I moved into my house, I wasn't able to set up using the Configure.Me-xxxxxxx. Check the inside of your network cabinet. In the inside of the door was a sticker. It listed a "WiFi Name" Lennar-xxxxxxxx followed by the password.
Try setting it up that way.
07-06-2021 11:49 AM
Shoot, I mis-read your model number. No. the 8 port only supports switch code at this time, but let me ask a few folks internally if that plans to change. You'll need to run router code to be able to make this work. Let me find out what I can for you.
07-06-2021 12:08 PM
@matt_klouda I don't mind buying something, I just don't want to rent from my ISP.
07-06-2021 12:23 PM
Take a picture and post it here of what's connected to your Cox modem now. Then I think I can get you a good solution.
07-06-2021 12:29 PM
07-06-2021 12:44 PM
@matt_klouda Matt, is the ICX-7150-C12P capable of functioning as an Internet gateway? Does it do NAT? Does it support DHCP server? Nobody is training the people who set these up how to use the ICX-7150-C12P as an Internet gateway, just as an L2 switch and PSE.
BTW - that looks like the C12P in the picture.
