09-07-2023 07:13 PM
After losing power, my ceiling WAPs stopped receiving power from the POE cable.
The internet is still feeding to the WAP units. I tested this by plugging the POE cable directly into my computer and the Internet works great. I have also tested the WAPs by plugging them in directly to a power source and they come back online and work great.
How do I get my switch unit to start pushing power to the WAP units again via the POE cable?
09-11-2023 06:11 PM
here's a different angle
09-12-2023 06:23 AM
Hi @Patty
Thanks for your response.
From the case description, I could understand that your PoE devices are not working connected to the ICX-7150-C12P Switch.
As you mentioned that on your ICX-7150-C12P Switch, the SYST and PWR lights are steady green, which means the lights are in a normal state.
Since the switch is in the normal state you can take Console access to the switch in order to verify, if the switch is able to transfer the power to PoE devices via 12 ports.
To check this, first, we have to get access to the switch, and there are Two ways to get access to the switch.
ICX7150-C12 Router>
Show version
Show inline power
Show inline power detail
Once you are logged in to the ICX-7150-C12P please follow up the same steps that are on point '2'
09-12-2023 09:39 AM
canoe
09-12-2023 10:27 AM
Hi @Patty
For further troubleshooting steps please share the output of the below commands by following the steps mentioned in the previous posts.
Show version
Show inline power
09-12-2023 12:55 PM
