Ruckus unleashed connectivity issues
Avila-Unleashed
Ruckus Unleashed is no longer connecting at home.
1 ACCEPTED SOLUTION
Hi — could you please cancel my request? I accidentally pressed the status button while dusting the unit to keep it dust‑free. That was my mistake. Thank you for reaching out.
3 REPLIES 3
pinky_ruckus
Hello @Avila-Unleashed ,
As per the case description, I understand that your RUCKUS setup is not working and your Unleashed network as well.
Could you please confirm if there are any lights on the AP?
On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture and share a picture of the same, showing the light status and the FULL Switch panel cable connections to the Switch ports)
Also, please share the light status of your Access points as well as mentioned in the below picture:
We are glad to know that the issue is resolved.
