04-14-2023 01:20 PM
My power went out for 2 hours. After power was restored, I noticed my ruckus switch wireless network is not working. I noticed the green power light on the switch as well as the amber SYST lights are illuminated. However, none of the access points are receiving power. So far, I’ve unplugged my AT&T internet modem and the ruckus switch in an effort to restart them, but it didn’t work. I also tried the reset button on the switch, but that didn’t work either. The AT&T internet does work which means it’s an issue with the ruckus, please help!
04-16-2023 03:22 AM
Hi Waltes01
Thank you for reaching out to us.
Could you please let me know if you are from Lennar homes ?
Could you please help me with Switch model that you are facing issue with ?
Could you please share picture of front panel of the switch when powered on ?
04-16-2023 05:49 AM
Yes it’s a Lennar home
switch model is ICX 7150-C12p
04-17-2023 12:07 PM
Hi @Waltes01
Hope you are doing well!!!
Thank you for the detailed information you shared,
As per the case description, I could understand that after a power outage, your ICX-7150-C12P Switch is not working and Access Points do not have power.
As I can see from the screenshot you shared, there is an amber/orange light on the "SYST" and a green light on the "PWR" on the Switch. Meaning the Switch is stuck in the boot mode.
Basically, due to the power outage/ power spike, the switch went to a state that we call ‘boot mode’ that is not able to boot up properly.
Please do not worry, it will not erase any password or configuration from the Switch or any devices.
As you already know first we will try to reset the Switch as described below:
Please let us know once you finish this process. So that we could assist you in upgrading your Switch to the latest stable version to avoid these issues in the future.
Lennar Home Community.
