โ01-12-2023 09:50 AM
My Ruckus has no power, no lights of any kind. I have plugged it into many functioning outlets to make sure. How do I get a replacement? Can I get a replacement? Do I need a replacement?
โ01-12-2023 12:16 PM
Hi @JC04
Please follow the below steps to find the root cause of the issue.
3- Make sure it is plugged into a well-known outlet/power source
4- Are the Access Points R510 powering up?
5- Are you having any connectivity issues like webpage not loading or slow connectivity.
โ11-29-2024 01:30 AM
If your Ruckus device has no power or lights:
โ11-29-2024 04:08 AM
Thank you for your suggestions @modcarparking
โ11-30-2024 02:18 AM
If your Ruckus device has no power or lights, try these steps:
If it's out of warranty, you may need to buy a new one.
