08-20-2024
08:55 AM
- last edited on
08-20-2024
08:58 AM
by
Imran_ruckus
After a lightning strike across the street, my ruckus box stopped working. It’s been reset multiple times and nothing. This has happened before, 3 years ago, and the box needed to be replaced. I called and was told to post this here and I should get a response from a tech.
thx
ruckus ICX 7150-C12P
SN: *****
08-20-2024 09:01 AM
Hi @mikib973
I recommend again attempting a physical factory reset multiple times, as outlined in our RUCKUS Lennar Knowledge Base self-help article accessible through this link and VIDEO:
If the initial reset attempts do not resolve the issue, please try resetting your switch multiple times (approximately 10-15 times) using the method described in the article. In some cases, repeated attempts have successfully resolved similar issues. Upon successful reset, the SYST and PWR lights should turn GREEN.
If hard reset doesn't work, please proceed with the below process:
08-26-2024 05:26 AM
Hi @mikib973
Thank you for your update.
I look forward to receiving the video so that we can proceed accordingly.
I appreciate your patience and understanding.
08-28-2024 05:31 AM
Hi @mikib973
Thank you.
08-28-2024 05:49 PM
The videos and photos are on the Google drive.
08-29-2024 05:31 AM
Hello @mikib973
Thank you for providing the videos and pictures.
From the materials you’ve shared, in one of the videos it appears that when both the PWR and SYST LEDs are green, that means the switch is in a normal operational state. Please confirm if this is currently the case.
However, I noticed that in one of the videos, all LEDs were blinking amber, which suggests that the switch may be experiencing issues with rebooting. In this situation, performing a software recovery of the switch is recommended. Please refer to the RUCKUS Lennar Knowledge Base article linked below for detailed instructions on the software recovery process:
Please follow the outlined procedure, and do not hesitate to reach out if you require any assistance during the process.
08-29-2024 10:48 AM
I tried resetting multiple times and got nothing. I’m going to need to have a friend help out because I’m not computer savvy enough to do all these step that are required to re flash the switch. I’ve got pictures of the top of the box that shows what looks like burn marks on the grates. Not sure if re flashing will help it because it looks like it’s fried. I don’t know what else I need to do, this box obviously needs to be replaced.
