07-20-2023 10:07 AM
I am having an issue of the Ruckus R510 APs rebooting (cycling off and on) multiple time per day, random time frames. I have power cycled the modem and switch and rest the APs but still cycling. It just ran for 2 and 1/2 hours and now just rebooted. The system rebooted for about 10 minutes and then cycled again.
The switch is a ICX 7150-C12P. The lights that are on are the Port Link Status, System Status and Power. All are green.
On the APs, the Pwr, 2.4G and 5G lights are green. Sometimes the CTL is green.
I am not sure where to get the current version of the Unleashed system.
07-20-2023 05:25 PM
These solutions require a Windows PC and I do not have one that I can install software on. What other options do I have?
07-21-2023 06:19 AM
Good morning ! Trying to find a Windows PC. Is there another option to try?
07-21-2023 08:58 AM
Hi @cwdarnell
You could try to get console access on MAC described at the end of the below guide.
However, we suggest using a Windows machine for an easier upgrade.
07-20-2023 12:42 PM
I'm having the same issue ever since I upgraded to the latest version 200.14.6.1.199. My two APs are running the same version, so I'll be keeping tabs on this thread to see if there will be a resolution.
Ned
07-20-2023 12:59 PM
Hi @nnedev
Hope you are doing well
As this case is raised by @nnedev
To avoid confusion with posts, you can create your own post with the problem you're facing and a detailed description of the network issue and what you've done so that we can guide you properly.
