Ruckus R510 Series issues with connecting to site
Overlook19
I recently have had issues with my connectivity and I believe it is linked to the Ruckus Extenders. I have had AT& T come out and update all of my equipment and I am still having issues. I have to switch back and forth between networks.
I am now trying to access via the app, however, the network to connect to the extenders does not populate.
I have rebooted the ruckus extender and still no network has appeared.
please advise
6 REPLIES 6
Valued Contributor III
Hi @Overlook19
Greetings of the day,
Thanks for your response,
For detailed understanding of the issue please share the LED status of the switch and the access points using the below guide.
R510 LED lights
RUCKUS LED lights
Also please upload the image of the switch and the access points showing the LED status and the cable connections.
Also please try to login to the unleashed dashboard and share the status of the switch as mentioned below.
Hello, as mentioned in the original message, I am having issues connecting to the dashboard as the ruckus wireless connection is not appearing.  
this is 1 of 2 ruckus
 this is 2 of 2 ( this one is closest to the big ruckus white box.
The  yellow light is flashing
Hi @Overlook19
Please try to reset your switch by using the below steps and let us know the result.
1-Try to disconnect from the Power outlet the ICX- 7150 and reconnect it.
2-Once you are done with the step please try to press the reset button using a paper click or a small stick
  1.  Remove power from the switch.
