01-02-2024 09:04 PM - edited 01-02-2024 09:09 PM
I recently have had issues with my connectivity and I believe it is linked to the Ruckus Extenders. I have had AT& T come out and update all of my equipment and I am still having issues. I have to switch back and forth between networks.
I am now trying to access via the app, however, the network to connect to the extenders does not populate.
I have rebooted the ruckus extender and still no network has appeared.
please advise
03-07-2024 06:46 PM
Good Evening,
I have attempted several times with the reset, but I am still having major issues with my internet connection.
03-08-2024 05:15 AM - edited 03-08-2024 05:15 AM
Hi @Overlook19
As per the case description, I understand that your RUCKUS setup is not working.
3. Is your Internet Connection from the Internet Service Provider (ISP) stable and working? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from the Router to a laptop/PC).
Please let me know the answers to ALL the above queries or let me know if you have any queries in this regard.
