08-04-2023 04:23 PM
My device is powering up anymore and has not lights on either. I have tried multiple power cables and power cycled the device and router as well. Online forums suggest to reset it with a pin have not worked either.
02-12-2024 06:34 AM
Hi @Pinderhayer
As per the case description, I understand that your RUCKUS setup is not working, and Access Points do not have power.
Kind regards,
Sofia Gätjens
02-12-2024 01:40 PM
Yes everything was working before than one day it just lost power and everything along with it. There was no outage around the time the ruckus stopped working.
there are two access points - there are no lights on these either.
the ISP works well and consistently. plugged in - outlet is working (lit up green) unit has no. power
access point 1
ap 2
02-19-2024 04:07 AM
Hi @Pinderhayer
I can see that none of the APs or your ISP is connected to the ICX switch.
Please check the link below to know the Most common Setups for Lennar homes users:
Kind regards,
Sofia Gätjens
02-28-2024 06:55 PM
Hello
Yes I have tried what the link suggests as well. Normally everything is connected to the ICX switch. But the picture posted was to show you there is absolutely no power going to the ICX, so even if I were to plug the AP's to the ICX there is no power - which is the issue I am having.
02-29-2024 04:27 AM
Hi @Pinderhayer
Could you please plug your ICX-7150-C12P Switch into a working power outlet and send us PICTURES and VIDEO of it showing the light status, and cord connected to the Switch and a working power outlet? Please refer to the below pictures as an example.
