Ruckus ICX7150 and APs not powering up
Pinderhayer
My device is powering up anymore and has not lights on either. I have tried multiple power cables and power cycled the device and router as well. Online forums suggest to reset it with a pin have not worked either.
14 REPLIES 14
Imran_ruckus
Hi @Pinderhayer
Hope you are doing well!!!
As per the case description, I could understand that your RUCKUS ICX-7150-C12P Switch is not powering up.
As you mentioned that you tried reset, once again we will try to reset the Switch as described below:
  • Remove power from the switch.
  • Press and hold the Reset button while applying power to the switch.
  • After all the system LEDs flash amber, release the Reset button.
IF RESET IS NOT WORKING, PLEASE TRY TO RESET YOUR SWITCH MULTIPLE TIMES (Like 10-15 times) AS DESCRIBED ABOVE.
Hi Imran - thank you for this recommendation. I tried over 20 times and am still having no luck with my Ruckus system getting back online. Even my access points seem to have lost power / connection.
any further help would be greatly appreciated.
Hi @Pinderhayer
Could you please plug your ICX-7150-C12P Switch into a working power outlet and send us PICTURES and VIDEO of it showing the light status, and cord connected to the Switch and a working power outlet? Please refer to the below pictures as an example.
Hello Imran, I know it has been a while since you sent this solution - right now I was about to take those pictures and upload them. As I plugged the Ruckus in it lit up, however despite being powered up and plugged into the ISP it is not providing a connection to any devices connected to it. Could you help me out with this?
Type a product name
