Ruckus ICX 7150-C12P Power Supply
noypi-cker
Does anyone know where to purchase a replacement power supply for ICX 7150-C12P?
Thanks,
1 ACCEPTED SOLUTION
Hi @noypi-cker
Greetings of the day!!!
Thank you for sharing the requested PICTURES and a VIDEO.
Based on the troubleshooting done, your ICX-7150-C12P Switch is not powering up, and when plugged in, it flashes an amber light and then goes dark. And you confirm that the Switch is plugged into a well-known outlet/power source. However, the failure persists. This Switch unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
13 REPLIES 13
Hi @noypi-cker
Thank you for your response and the information provided.
Please keep me informed as needed so that I can assist you further.
Hi Imran,
I already tried to reset it 20 times but still the same. Mine does not have any green light only amber/orange light for split second on the STAT, SPD, ID, USB, POE, SYST, DIAG, MS, CLD, UPDATE, PWR.
Do you think it's a power supply issue?
Hi @noypi-cker
It doesn't seem to be a power supply issue from your power outlet since you tried from the different cords with the same result.
Hi Imran,
I already upload the photos and video. I created a folder named noypi-cker.
Thank you,
Hi @noypi-cker
