07-16-2025 09:08 AM
I had a power outage yesterday and when the system came back up the Ruckus ICX7150 was showing intermittent internet connectivity, and I am unable to connect to it using the Unleashed app on my phone. When I console in with putty, I see this prompt "ICX7150-C12-Router", which indicates that it is in router mode. I attempted to reboot the Ruckus ICX7150 from the Primary, using the command "boot system flash primary yes" but during the boot process I see the error message "could not boot from primary, no valid image; trying to boot from secondary". Any assistance on how to proceed would be greatly appreciated.
07-16-2025 09:32 AM
Hi @Lewthound ,
From the case description, I understand that you are facing intermittent connectivity issues with your APs after the power outage.
This issue is because your switch is running on the Routing code (SPR). The Switch should run on the Switching code (SPS) for Lennar home users. Due to a power outage/power spike, the Switch boots up on the other partition which may be running on a ‘Routing Code’ results in causing this issue.
Please follow the below RUCKUS Lennar Knowledge base self-help article which will help you to fix the issue when the Switch is running in the Routing code.
Please follow the process as explained in the article and let me know if you have any queries in this regard.
07-18-2025 03:12 PM
Hello @Lewthound ,
Could you please share the screenshot of the error message along with the output of the show flash command so that we could assist you further?
07-18-2025 04:03 PM - edited 07-18-2025 07:28 PM
Below are screenshots of the of the error message, the show version command, and the show flash command you requested. Let me know if you need any additional information.
07-21-2025 09:26 AM
Hello @Lewthound ,
I understand that you have connected the Switch using the console access.
Could you please try accessing the Switch CLI using the IP address through Putty option?
1) To check this, we must identify the ‘current’ IP address assigned by your local router to the switch ICX-7150-C12P
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
show version
show flash
07-21-2025 01:40 PM
I have resolved the issue of my ICX7150-C12 running Router code. I used the self-help article you recommended, from the RUCKUS Lennar Knowledge base linked below
After following those instructions, I rebooted the unit and saw that the ICX7150-C12 is now running Switch code, I confirmed this with the “show version” and “show flash” commands.
I now can connect to the access point with the Unleashed app as well as from my PC and devices plugged into ICX7150-C12 can access the Internet. I appreciate your assistance is resolving this issue.
07-21-2025 02:01 PM
Hello @Lewthound ,
We are glad to know that the issue is resolved, and all the devices are back online after changing into the Switching code.
Please feel free to contact us if there are any issues in this regard in future.
