02-09-2025 06:04 PM
I have been struggling with my ruckus access points since the last power outage, now the APs are blank with know no power. I’ve tried every solution proposed in the posts and watch countless video without having any success.
I have tried resetting. I even tried logging into the IP. The Rukus doesn’t even show on wireless networks to anything via WiFi.
I’ve also tried calling, but due to me purchasing a Lennar home no one would help me over the phone. Please help this is beyond exhausting and frustrating. Please help!
02-10-2025 05:48 AM
Hi @McD87,
As per the case description, I understand that your Access points are no longer turning on after the power outage.
2. May I know how many Access Points are connected to the Switch? Could you please let me know the light status on the Access Points? Any of these lights are on (Please refer to the below picture and share a picture of the same)
02-10-2025 05:57 AM
Thank you for your response.
Hello there are green lights showing on the switch, but access points have no power. I have two access points. One upstairs and one downstairs. Please assist.
02-10-2025 06:30 AM
Hi @McD87 ,
From the response shared, the lights on the Switch is normal and switch is working and there are no lights in the access points, it is always good to check if the PoE is disabled or not.
Please follow the below RUCKUS Lennar Knowledge base self-help article which will help you to check if the PoE is disabled and to fix the issue if it is disabled.
Please follow the process and let me know if you need any help during the process.
02-13-2025 04:28 PM
I have used the link provided and I am unable to log into my switch. The common passwords do not work. I have also noticed that the light on the status in illuminating.
Please assist. Thank you
