04-27-2023 01:55 PM
The AP is most likely stuck in boot loop no longer functioning. I recently moved into the house that has this Ruckus hardware and it is the only AP that's dead. The other two are working fine.
I have tried the same thing as this forum member, same problem.
Is the AP still under warranty and how can I get a replacement?
09-07-2023 08:08 AM
Hi @Patty
Hope you are doing well
As this case is raised by @DL
To avoid confusion with posts, you can create your own post with the problem you're facing and a detailed description of the network issue and what you've done so that we can guide you properly.
