Ruckus AP R510 Power LED SHOWING RED
DL
The AP is most likely stuck in boot loop no longer functioning. I recently moved into the house that has this Ruckus hardware and it is the only AP that's dead. The other two are working fine.
I have tried the same thing as this forum member, same problem.
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/AP-R510-PWR-light-stays-red/...
Is the AP still under warranty and how can I get a replacement?
5 REPLIES 5
Hi @Patty
Hope you are doing well
As this case is raised by @DL
To avoid confusion with posts, you can create your own post with the problem you're facing and a detailed description of the network issue and what you've done so that we can guide you properly.
