08-08-2023 04:17 PM
After power outages, my Ruckus switch stays in boot mode, SYST light is yellow. I was able to connect from my laptop using a USB-C cable and ran the command BOOT_PRIMARY, which shows that it goes to the secondary to actually boot and then works.
I am trying to run the software upgrade per your article:
However, using a USB-C connection, it does not show up as a Network device, so I do not know how to configure the IP address (Gateway, Server IP, etc) in order to push the image files to the switch. I am able to run off the secondary image so far, but that could become corrupt at some point like the primary and I won't be able to use my switch anymore. Can you provide the steps on how to perform the software update using the USB-C connection, NOT the ethernet connection.
Thank you,
Manuel
08-21-2023 08:25 AM
Hi @LenRuck2023
Yes, Telnet will not ask for a username/password to log in. And there should be 3 files in the Upgrade folder as mentioned in the Upgrade guide/post.
Please follow the below steps as shown in the screenshot.
1. Browse and select the Upgrade folder containing 3 .bin files.
2. Click on ‘Show Dir’>>select 1st file>>hit copy
3. Open the CLI/Telnet and type the below command and copy the mnz10114.bin file by right click on the mouse. (Ex: copy tftp flash <ip address> <right click> bootrom) Press Enter and now your tftp image will start copying.
Command: copy tftp flash 10.45.19.152 spz10114.bin bootrom
Follow the next step-by-step process from the guide carefully and repeat the above step for the other 2 files as well.
