06-11-2023 04:54 PM
Reset house power while troubleshooting an electrical issue, now Ruckus access point network is very slow or fails to load url requests despite speed testing well. Ruckus app won’t allow me to log in to manage the AP based network.
06-12-2023 02:01 PM
Carefully following the CLI for ssh into the box was the ONLY way this was fixable. I'm not certain why the GUI is suggested, it failed at least 5 times.
The GUI and CLI both now report that the SPS prefixed boot image is being used to boot, and I've overwritten the secondary boot image with the SPS to eliminate the possibility of this happening again.
Are there any guided workflow articles on updating the firmware from 90 to 95?
06-12-2023 06:39 AM
Hi @scoobyjroo
Greetings of the day,
Please confirm if the issue is happening while it is connected to access points or when it is connected to ISP router.
Please follow out the next steps.
1. Connect the computer to the ISP router with the ethernet cable. Run the speed test, and confirm if your speed is stable and search for websites, make sure you have no issues.
2. You can perform the same step on wireless by connecting the computer to the Wi-Fi / SSID coming from the ISP router. (Note: Not the Wi-Fi coming from the access
Please perform the above steps and let us know the result.
06-12-2023 09:15 AM
1. Have done, ISP router speeds are normal, load times are standard.
2. ISP WiFi speeds are also normal.
06-12-2023 10:00 AM
Hi @scoobyjroo
Thanks for your response.
Based on your troubleshooting done, it seems that your switch (ICX7150 Switch) may be booting from the secondary partition (NOTE: Secondary partition contains the routing code) which is causing the bad connectivity issues. This could happen after multiple power outages, please follow up the next guide.
Guide#1 for CLI:
Guide#2 for CLI:
Note: if you have access to the Unleashed Dashboard and the Switch can be seen from there, it may look like the following image, ICX7150-C12-Router instead of ICX7150-C12-Switch, now before starting the steps of the guide, I will advise you to cable the computer directly to the Switch, since you will have a better connectivity than if you connect via wireless.
4 How to Fix Routing code issues on Lennar Home users via Web GUI.
. After fixing the issue of the Switch booting from the wrong partition, please perform an upgrade to the code 08095g UFI and upgrade both partitions primary and secondary with the switching code file named SPS08095gufi.bin, take into consideration that is the Switch is running a code lower than 08080 you need to upgrade twice, from the code you are to 08080f and then the recommended code 08095g UFI.
Upgrade a switch via Web GUI (ICX7150 Switch)
06-12-2023 10:25 AM
That first link is a dead link, but I'll attempt the others and report back. If you have an updated link for the first guide, please post it here. Thank you for the assistance. Any power related issues that could apply would make sense in my case, due to the power cycle down on the house's power.
