Re: No power to AP’s from switch
BlowBoatTech
I got the instructions to start a system reboot however there is a flaw in the instructions.  See attached. When I need to locate which COM is connected to the switch, these modern day computers don't show a COM1. It list the switch under  Other devices. I need to know how to put the device into the PuTTY for a PC x64. I can't get past PuTTY.
23 REPLIES 23
pinky_ruckus
Hello @BlowBoatTech ,
As per the case description, I understand that your RUCKUS setup is not working and the APs do not have power.
I would request you to please connect to the CLI of the Switch using the console cable.
Please follow the below RUCKUS Lennar Knowledge base self-help article which will help you to console in the ICX-7150-12CP 'Ruckus Switch
Also, the system showing Amber lights as the Switch is stuck in the boot mode.
Please follow the below RUCKUS Lennar Knowledge base self-help article which will help you to fix the issue when the Switch is in boot mode.
https://community.ruckuswireless.com/t5/RUCKUS-Lennar-Support-Knowledge/Fixing-RUCKUS-Switch-with-an...
Please follow the process as explained in the article and let me know if you have any queries in this regard.
pinky_ruckus
pinky_ruckus
pinky_ruckus
Thank you.
