Re: NO Power on Access Points and ICX-7150-C12P Switch with Yellow and GREEN lights on SYST & PW
Afofrancozola
I had another power outage and tried the following steps about to restore the PoE but getting this issue when trying to load the images using this steps
https://community.ruckuswireless.com/t5/RUCKUS-Lennar-Support-Knowledge/Fixing-host-192-168-0-x-is-n...
This is the image of error i am getting on Putty console
Can you assist ?
5 REPLIES 5
pinky_ruckus
Valued Contributor III
Hello @Afofrancozola ,
As per the case description, I understand that your Ruckus Switch is not working after the power outage.
Also, could see that you have tried to perform reset multiple times and cant get  kernel image.
Could you please share a picture of the software recovery cable connections between Switch and laptop?
Afofrancozola
This is the image of the cable been used
I would request you to please refer to the below pictures and connect the cables before performing the Software recovery.
A console cable connected between your Computer to the ICX 7150 Switch Type-C USB console port.
Note: The cable type will be USB to type C, where the USB it’s going to your computer and the type C to the Type C connection in your switch
Ethernet cable connected between the Out-of-band management port in the Switch to your computer Ethernet port.
Please complete the software recovery process after connecting the cables as mentioned in the above figures and let me know if you have any queries in this regard.
