Re: Issue with Ruckus ICX 7150 Switch
Eldude65
Good morning. I have the same issue and attempted to follow the instructions. However, I cannot find my switch's IP address at all when using the advanced IP scanner. When looking on the Unleashed Dashboard, as well, the switch has no IP address. I took a screenshot of the original IP address, but cannot connect or ping it as it is unreachable.
15 REPLIES 15
pinky_ruckus
Valued Contributor III
Hello @Eldude65 ,
Please share the pictures of the Switch connection cables as well as the Access points.
Also, we would request you to access CLI of the Switch through console cable.
Please follow the below RUCKUS Lennar Knowledge base self-help article which will help you to console in the ICX-7150-12CP 'Ruckus Switch
Please let us know if you are able to access the CLI of the Switch using the console cable.
Hello. I can access the CLI of the switch
pinky_ruckus
Hello @Eldude65 ,
Thank you for sharing the pictures.
To proceed further, we would need to check few configurations of the switch.
As you are able to access the CLI through console, the Command line should look like this:
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
Once you login to CLI, please enter the below commands and share the output.
show version
show flash
pinky_ruckus
Hello @Eldude65 ,
pinky_ruckus
Hello @Eldude65 ,
