11-23-2024 08:22 AM
Good morning. I have the same issue and attempted to follow the instructions. However, I cannot find my switch's IP address at all when using the advanced IP scanner. When looking on the Unleashed Dashboard, as well, the switch has no IP address. I took a screenshot of the original IP address, but cannot connect or ping it as it is unreachable.
11-25-2024 04:18 AM
Hi @Eldude65
Based on the information provided, it appears that you are encountering issues with accessing the RUCKUS ICX-7150-C12P Switch as you cannot find its IP address.
If you are unable to get the IP address of the Switch, please try getting console access to the Switch.
Here is a guide on how to access to the Switch via console (cable access between your PC to the ICX 7150-C12P) in this case we need a USB type C to USB standard OR Console cable Rj45 to USB (Any one cable- please refer the guide)
Please let me know once you are able to get the console CLI access please help me with the below commands.
show version
show flash
11-27-2024 04:18 AM
Hi @Eldude65
Thank you.
11-29-2024 04:23 AM
Hi @Eldude65
Thank you.
12-01-2024 02:04 AM
Yes! Apologies for not responding. I've been under the weather the past few days and am finally recovering.
I have internet and am good to go. It was weird. Once I power cycled the network switch worked again without issue.
