Re: Issue with Ruckus ICX 7150 Switch
Eldude65
Good morning. I have the same issue and attempted to follow the instructions. However, I cannot find my switch's IP address at all when using the advanced IP scanner. When looking on the Unleashed Dashboard, as well, the switch has no IP address. I took a screenshot of the original IP address, but cannot connect or ping it as it is unreachable.
3 REPLIES 3
Imran_ruckus
Hi @Eldude65
Based on the information provided, it appears that you are encountering issues with accessing the RUCKUS ICX-7150-C12P Switch as you cannot find its IP address.
If you are unable to get the IP address of the Switch, please try getting console access to the Switch.
Here is a guide on how to access to the Switch via console (cable access between your PC to the ICX 7150-C12P) in this case we need a USB type C to USB standard OR Console cable Rj45 to USB (Any one cable- please refer the guide)
Please let me know once you are able to get the console CLI access please help me with the below commands.
show version
show flash
Imran_ruckus
Hi @Eldude65
Thank you.
Imran_ruckus
Hi @Eldude65
Thank you.
