Re: Faulty equipment, need an RMA
BillRamos
It went out again. The switch is bad. I need tech support that can talk to me or that can come out or I need an RMA.
1 REPLY 1
pinky_ruckus
Valued Contributor III
Hi @BillRamos ,
As per the case description, I understand that your RUCKUS switch is not working.
  1. Was there any power outage before you started facing this issue?
  2. On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture and share a picture of the same, showing the light status and the FULL Switch panel cable connections to the Switch ports)
3. May I know how many Access Points are connected to the Switch? Could you please let me know the light status on the Access Points? Any of these lights are on (Please refer to the below picture and share a picture of the same)
