08-15-2023 01:52 PM
I recently moved into a Lennar home and am trying to connect the wifi. After looking at the setup guide, I have an issue with the R510 not powering on for connection. Please advise.
08-31-2023 01:44 PM
Hi @KColeman
Could you please unplug the current Access Points, plug the other Access Point, perform the factory reset on it, and check?
08-31-2023 04:59 PM
Hi @KColeman
Since you have 2 R510 APs. As mentioned in my previous post, could you please unplug the current Access Point, plug the other Access Point, perform the factory reset on it, and check?
08-31-2023 04:42 PM
It's doing the same thing with the other port.
09-01-2023 05:05 AM
I tried resetting the 2 R510 APs, and neither holds any connectivity after the reset.
09-01-2023 08:07 AM
Hi @KColeman
As per the light status after the reset, the Internet connectivity should work.
We suggest you check your ISP (Internet Service Provider) Internet connectivity and also you can try replacing the ethernet cable that connects from the ISP Router to the RUCKUS Switch in case it is damaged.
Also please share a CLEAR Picture showing the connectivity from your ISP Router and the RUCKUS Switch.
