Showing results forย
Search instead forย
Did you mean:ย
R510 does not power on
hootanhemmat
I have the ICX-7150 which is powered on and shows green lights. I have two R510s on two different floors that wont turn on. I took one off the ceiling and connected it to a 12VDC and a different POE and it turns on but when connected to the ethernet cable coming out of the ceiling, it does not work.
20 REPLIES 20
I need assistance with an issue affecting two R510 access points (APs) in my home, located in the living room and upstairs. Both APs were previously powered solely via PoE through Ethernet cables. Recently, both have simultaneously stopped receiving power via PoE and now require direct electrical power from the wall to operate.
Summary of the Issue:
1. Previous Setup:
โ€ข Both R510 APs were functioning properly with power and data supplied via PoE Ethernet cables.
2. Current Problem:
โ€ข Both APs have stopped receiving power through PoE and now need to be plugged into an electrical outlet.
โ€ข The Ethernet cables are confirmed to be working for data transmission but no longer provide power.
Tests and Observations:
1. Verification of Ethernet Cables:
โ€ข All Ethernet cables have been tested and are functioning for data transmission.
โ€ข Despite this, the APs are not receiving power via these cables.
2. Configuration Check:
โ€ข Using macOS and Terminal, we confirmed that the PoE setting is enabled and set to auto.
Request for Assistance:
Could you please help diagnose and resolve this issue? We need to understand why the APs have stopped receiving power via PoE and now require direct electrical power.
Thank you for your assistance.
pinky_ruckus
Valued Contributor III
Hello @hootanhemmat ,
I understand that you are still facing issues not connecting to the PoE of the AP.
To proceed further, we need to check few configurations on the Switch.
Once we identify the IP address of the switch proceed to access remotely to the device โ€œCommand Lineโ€
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
show version
show flash
show inline power
show inline power detail
show interface brief
pinky_ruckus
Thank you for the response and sharing the screenshot.
From the screenshots you shared, it looks like you are using command line interface of unleashed and not a Switch.
The commands should be executed in the Switch CLI.
Please follow the below RUCKUS Lennar Knowledge base self-help article which will help you to console in the ICX-7150-12CP 'Ruckus Switch
Please follow the article and let me know if you have any queries in this regard.
pinky_ruckus
