08-22-2023 05:11 AM - edited 08-22-2023 05:17 AM
One of my R510 APs power light is stuck on red. I have followed these instructions and it continues to stay red.
How to factory reset or factory default different types of Ruckus Access points? (technical guide.)
https://support.ruckuswireless.com/articles/000012418
Please let me know if I need a RMA.
08-30-2023 09:41 AM
Hi @flo253
Could you please let me know if you have an external power adapter (12VDC) to connect to the R510 Access Point and check it separately without connecting to the Switch PoE port cable? (Please refer to the below screenshot)
Please confirm.
08-30-2023 07:15 PM
Yes I do.
08-31-2023 08:41 AM
Hi @flo253
Thank you for the response and the confirmation.
Please unplug the ethernet cable from the PoE port of the AP and connect the AP with a 12 VDC Adapter ALONE. Perform the factory reset process, by pressing the reset button with a paper clip on AP and try connecting configure.me.xxxxxx Wi-Fi SSID broadcasted from that AP to configure and check. Please refer to the below guide and video for the factory reset process.
09-13-2023 04:04 PM
How to I get the AP off the ceiling? I’m trying to push the AP so the screws come loose from the mount but it’s not going anywhere. I’m over this.
09-13-2023 04:59 PM
Hi @flo253
You need to use a paper clip to unmount it. Please refer to the below video from 3:30 Minutes to know how to get the AP off the ceiling.
https://www.youtube.com/watch?v=vFD_ByQWGH0&t=42s
