02-04-2026 01:02 PM
I am unable to connect to my Ruckas AP as of today. Everything has been working fine for a long time.
I am able to connect directly to my Cox modem both hard wired and wirelessly.
After a number of reboots and restarts, I'm getting the same results. The 4 lights on my AP are solid green.
When I try to connect to my Lennar network wirelessly, I either get "connection failed" or "connected without internet"
Here are photos of my switch and AP.
Any suggestions on how to get things working again are much appreciated.
Thanks,
02-04-2026 04:03 PM
Here is more of what you asked for:
show flash and show inline power
SSH@ICX7150-C12-Switch#show flash
Stack unit 1:
Compressed Pri Code size = 29360128, Version:08.0.90jT211 (SPS08090j.bin)
Compressed Sec Code size = 33554432, Version:08.0.90jT213 (SPR08090j.bin)
Compressed Pri Boot Code size = 786944, Version:10.1.18T225 (mnz10118)
Compressed Sec Boot Code size = 786944, Version:10.1.18T225 (mnz10118)
Code Flash Free Space = 1260429312
SSH@ICX7150-C12-Switch#show inline powerr
Invalid input -> powerr
Type ? for a list
Power Capacity: Total is 124000 mWatts. Current Free is 108600 mWatts.
Power Allocations: Requests Honored 13 times
1/1/1 On Non-PD 0 0 n/a n/a 3 n/a
1/1/2 On Non-PD 0 0 n/a n/a 3 n/a
1/1/3 On Off 0 0 n/a n/a 3 n/a
1/1/4 On Off 0 0 n/a n/a 3 n/a
1/1/5 On On 3300 15400 802.3af Class 3 3 n/a
1/1/6 On Off 0 0 n/a n/a 3 n/a
1/1/7 On Non-PD 0 0 n/a n/a 3 n/a
1/1/8 On Off 0 0 n/a n/a 3 n/a
1/1/9 On Non-PD 0 0 n/a n/a 3 n/a
1/1/10 On Off 0 0 n/a n/a 3 n/a
1/1/11 On Non-PD 0 0 n/a n/a 3 n/a
1/1/12 On Non-PD 0 0 n/a n/a 3 n/a
Total 3300 15400
02-04-2026 06:07 PM
Here is more of the information you requested on:
show flash, show inline power, show interface brief and show lldp neighbors detail
login as: admin
Keyboard-interactive authentication prompts from server:
| Password:
End of keyboard-interactive prompts from server
SSH@ICX7150-C12-Switch>show flash
Stack unit 1:
SSH@ICX7150-C12-Switch>show inline power
1/1/5 On On 3400 15400 802.3af Class 3 3 n/a
Total 3400 15400
SSH@ICX7150-C12-Switch>show interface brief
Port Link State Dupl Speed Trunk Tag Pvid Pri MAC Name
1/1/1 Up Forward Full 1G None No 1 0 70ca.9722.a39e
1/1/2 Up Forward Full 1G None No 1 0 70ca.9722.a39f
1/1/3 Down None None None None No 1 0 70ca.9722.a3a0
1/1/4 Down None None None None No 1 0 70ca.9722.a3a1
1/1/5 Up Forward Full 1G None No 1 0 70ca.9722.a3a2
1/1/6 Down None None None None No 1 0 70ca.9722.a3a3
1/1/7 Up Forward Full 100M None No 1 0 70ca.9722.a3a4
1/1/8 Down None None None None No 1 0 70ca.9722.a3a5
1/1/9 Up Forward Full 1G None No 1 0 70ca.9722.a3a6
1/1/10 Down None None None None No 1 0 70ca.9722.a3a7
1/1/11 Up Forward Full 1G None No 1 0 70ca.9722.a3a8
1/1/12 Up Forward Half 10M None No 1 0 70ca.9722.a3a9
1/2/1 Down None None None None No 1 0 70ca.9722.a3ab
1/2/2 Down None None None None No 1 0 70ca.9722.a3ac
1/3/1 Down None None None None No 1 0 70ca.9722.a3ad
1/3/2 Down None None None None No 1 0 70ca.9722.a3ae
mgmt1 Down None None None None No None 0 70ca.9722.a39e
SSH@ICX7150-C12-Switch>show llpd neighbors detail
Invalid input -> llpd neighbors detail
Type ? for a list
SSH@ICX7150-C12-Switch>show lldp neighbors detail
Local port: 1/1/5
Neighbor: 3420.e316.2b00, TTL 95 seconds
+ Chassis ID (MAC address): 3420.e316.2b00
+ Port ID (MAC address): 3420.e316.2b00
+ Time to live: 120 seconds
+ System name : "RuckusAP"
+ System description : "Ruckus R510 Multimedia Hotzone Wireless AP/SW Ver\
sion: 200.9.10.4.212"
+ System capabilities : bridge, WLAN access point, router
Enabled capabilities: bridge, WLAN access point
+ Management address (IPv4): 192.168.0.34
+ Port description : "eth0"
+ Link aggregation: capable, but not aggregated
+ 802.3 MAC/PHY : auto-negotiation enabled
Advertised capabilities: 10BaseT-HD, 10BaseT-FD, 100BaseTX-HD,
100BaseTX-FD, fdxPause, fdxAPause, 1000BaseT-FD
Operational MAU type : 1000BaseT-FD
Local port: 1/1/9
Neighbor: 1803.7330.1847, TTL 3478 seconds
+ Chassis ID (MAC address): 1803.7330.1847
+ Port ID (MAC address): 1803.7330.1847
+ Time to live: 3601 seconds
Advertised capabilities: 1000BaseT-FD
Operational MAU type : Other
+ MED capabilities: capabilities
MED device type : Endpoint Class I
02-05-2026 08:50 AM
Hello @relle444 ,
From the response you shared, I understand that the cable connections and light status looks normal.
I would request you to please create a new Wifi-network using the below mentioned article:
Please follow the article and let me know if you are able to connect to the RUCKUS Wifi network.
