02-04-2026 01:02 PM
I am unable to connect to my Ruckas AP as of today. Everything has been working fine for a long time.
I am able to connect directly to my Cox modem both hard wired and wirelessly.
After a number of reboots and restarts, I'm getting the same results. The 4 lights on my AP are solid green.
When I try to connect to my Lennar network wirelessly, I either get "connection failed" or "connected without internet"
Here are photos of my switch and AP.
Any suggestions on how to get things working again are much appreciated.
Thanks,
02-04-2026 01:57 PM
Hello @relle444 ,
As per the case description, I understand that you are facing issues connecting with the RUCKUS AP.
From the pictures you shared, it seems that the cable connections look normal.
Before we can help, we need to check few configurations on the Switch and which version the Switch is currently running.
1. To check this, we must identify the ‘current’ IP address assigned by your local router to the switch ICX-7150-C12P
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
show version
show flash
show inline power
show interface brief
lldp neighbors detail
02-04-2026 02:56 PM
Okay, Thanks for the help.
Here is what I got out of Putty.
Let me know if you have any questions.
Thanks,
Ron
login as: admin
Keyboard-interactive authentication prompts from server:
| Password:
End of keyboard-interactive prompts from server
SSH@ICX7150-C12-Switch>enable
SSH@ICX7150-C12-Switch#show version
UNIT 1: compiled on Jan 5 2021 at 21:06:08 labeled as SPS08090j
(29360128 bytes) from Primary SPS08090j.bin (Non-UFI)
SW: Version 08.0.90jT211
Compressed Primary Boot Code size = 786944, Version:10.1.18T225 (mnz10118)
Compiled on Mon Jul 13 08:53:29 2020
HW: Stackable ICX7150-C12-POE
UNIT 1: SL 1: ICX7150-C12-2X10GR POE 12-port Management Module
Serial #:FEK3831R12P
Current License: 2X10GR
8192 KB boot flash memory
2048 MB code flash memory
1024 MB DRAM
STACKID 1 system uptime is 3 hour(s) 31 minute(s) 51 second(s)
The system started at 00:03:48 GMT+00 Sat Jan 01 2000
=============== WARNING: FI image is not booted from UFI!!! ===============
====== Please download UFI image and reboot the system for full functionality ======
SSH@ICX7150-C12-Switch#show flash
Stack unit 1:
Compressed Pri Code size = 29360128, Version:08.0.90jT211 (SPS08090j.bin)
Compressed Sec Code size = 33554432, Version:08.0.90jT213 (SPR08090j.bin)
Compressed Pri Boot Code size = 786944, Version:10.1.18T225 (mnz10118)
Compressed Sec Boot Code size = 786944, Version:10.1.18T225 (mnz10118)
Code Flash Free Space = 1260429312
SSH@ICX7150-C12-Switch#show inline power
Power Capacity: Total is 124000 mWatts. Current Free is 108600 mWatts.
Power Allocations: Requests Honored 13 times
1/1/1 On Non-PD 0 0 n/a n/a 3 n/a
1/1/2 On Non-PD 0 0 n/a n/a 3 n/a
1/1/3 On Off 0 0 n/a n/a 3 n/a
1/1/4 On Off 0 0 n/a n/a 3 n/a
1/1/5 On On 3200 15400 802.3af Class 3 3 n/a
1/1/6 On Off 0 0 n/a n/a 3 n/a
1/1/7 On Non-PD 0 0 n/a n/a 3 n/a
1/1/8 On Off 0 0 n/a n/a 3 n/a
1/1/9 On Non-PD 0 0 n/a n/a 3 n/a
1/1/10 On Off 0 0 n/a n/a 3 n/a
1/1/11 On Non-PD 0 0 n/a n/a 3 n/a
1/1/12 On Non-PD 0 0 n/a n/a 3 n/a
Total 3200 15400
SSH@ICX7150-C12-Switch#show interface brief
Port Link State Dupl Speed Trunk Tag Pvid Pri MAC Name
1/1/1 Up Forward Full 1G None No 1 0 70ca.9722.a39e
1/1/2 Up Forward Full 1G None No 1 0 70ca.9722.a39f
1/1/3 Down None None None None No 1 0 70ca.9722.a3a0
1/1/4 Down None None None None No 1 0 70ca.9722.a3a1
1/1/5 Up Forward Full 1G None No 1 0 70ca.9722.a3a2
1/1/6 Down None None None None No 1 0 70ca.9722.a3a3
1/1/7 Up Forward Full 100M None No 1 0 70ca.9722.a3a4
1/1/8 Down None None None None No 1 0 70ca.9722.a3a5
1/1/9 Up Forward Full 1G None No 1 0 70ca.9722.a3a6
1/1/10 Down None None None None No 1 0 70ca.9722.a3a7
1/1/11 Up Forward Full 1G None No 1 0 70ca.9722.a3a8
1/1/12 Up Forward Half 10M None No 1 0 70ca.9722.a3a9
1/2/1 Down None None None None No 1 0 70ca.9722.a3ab
1/2/2 Down None None None None No 1 0 70ca.9722.a3ac
1/3/1 Down None None None None No 1 0 70ca.9722.a3ad
1/3/2 Down None None None None No 1 0 70ca.9722.a3ae
mgmt1 Down None None None None No None 0 70ca.9722.a39e
SSH@ICX7150-C12-Switch#lldp neighbors detail
Invalid input -> lldp neighbors detail
Type ? for a list
SSH@ICX7150-C12-Switch# Down None None None None No 1 0 70ca.9722.a3ad
Invalid input -> None None None None No 1 0 70ca.9722.a3ad
Type ? for a list
SSH@ICX7150-C12-Switch#1/3/2 Down None
02-04-2026 04:12 PM
Here is the last part of the date you requested.
Show interface brief and show lldp neighbors detail
SSH@ICX7150-C12-Switch#show lldp neighbors detail
Local port: 1/1/5
Neighbor: 3420.e316.2b00, TTL 119 seconds
+ Chassis ID (MAC address): 3420.e316.2b00
+ Port ID (MAC address): 3420.e316.2b00
+ Time to live: 120 seconds
+ System name : "RuckusAP"
+ System description : "Ruckus R510 Multimedia Hotzone Wireless AP/SW Ver\
sion: 200.9.10.4.212"
+ System capabilities : bridge, WLAN access point, router
Enabled capabilities: bridge, WLAN access point
+ Management address (IPv4): 192.168.0.34
+ Port description : "eth0"
+ Link aggregation: capable, but not aggregated
+ 802.3 MAC/PHY : auto-negotiation enabled
Advertised capabilities: 10BaseT-HD, 10BaseT-FD, 100BaseTX-HD,
100BaseTX-FD, fdxPause, fdxAPause, 1000BaseT-FD
Operational MAU type : 1000BaseT-FD
Local port: 1/1/9
Neighbor: 1803.7330.1847, TTL 3025 seconds
+ Chassis ID (MAC address): 1803.7330.1847
+ Port ID (MAC address): 1803.7330.1847
+ Time to live: 3601 seconds
Advertised capabilities: 1000BaseT-FD
Operational MAU type : Other
+ MED capabilities: capabilities
MED device type : Endpoint Class I
02-04-2026 03:58 PM
Hello, thanks for the instructions.
I think I have what you were looking for.
Here is what I copied from Putty. I will break this into multiple messages because of size of content.
Thanks,
Ron
enable & show version
login as: admin
| Password:
Access denied
| Password:
1024 MB DRAM
STACKID 1 system uptime is 4 hour(s) 34 minute(s) 0 second(s)
The system started at 00:03:55 GMT+00 Sat Jan 01 2000
