Power is not going to AP(s) from switch
tpatte15
I have (2) APs in the house that are not receiving power. I have tried to factory reset the switch but seems to be getting stuck trying to reset and lights will continue to blink 10+ min.
5 REPLIES 5
Valued Contributor III
Hi @tpatte15
Thanks for the response.
If the resetting process doesn't work, we need to perform a software recovery.
Note: after fixing the issue of the Switch been stuck in boot mode, please perform an upgrade to the code 08095g UFI and upgrade both partitions with the switching code file named SPS08095gufi.bin, so perform the software recovery using the code 08090k with the upgrade image file named SPS08090k.bin, then when the switch is back to normal upgrade to the file SPS08095gufi.bin for both partitions primary and secondary.
