07-31-2023 06:15 AM
I have (2) APs in the house that are not receiving power. I have tried to factory reset the switch but seems to be getting stuck trying to reset and lights will continue to blink 10+ min.
07-31-2023 08:02 AM
Hi @tpatte15
Thanks for the response.
If the resetting process doesn't work, we need to perform a software recovery.
