Power is not going to AP(s) from switch
tpatte15
I have (2) APs in the house that are not receiving power. I have tried to factory reset the switch but seems to be getting stuck trying to reset and lights will continue to blink 10+ min.
5 REPLIES 5
Valued Contributor III
Hi @tpatte15
Greetings of the day,
Please let us know the LED status of the switch and the access points using the below guide.
R510 LED lights
RUCKUS LED lights
no lights on the AP's
on the switch the power light is green (16) and the SYST is yellow/amber (7) when i push the port status mode selection button(1) no lights will recact in the status box.
Hi @tpatte15
Based on your description your switch has one green and one yellow light, it means that the switch is stuck in boot mode.
  1.  Remove power from the switch.
Thanks Jayavidhya,
I tried the factory reset last night after reading previous posts and once i relased the reset button the light jsut continued to flash well past a typical reboot time (10+ min)
