04-06-2024 02:30 PM
My switch is no longer transmitting a wifi signal or internet after power interruption. Internet gateway is working fine. Tries power recycle an it did not work
04-07-2024 11:06 PM - edited 04-07-2024 11:15 PM
Hi Kahboom,
Thank you for posting your query !!!
I understand that Switch is no longer transmitting a Wi-Fi signal or internet after power interruption and internet gateways is working fine and you already tried power cycle but the issue remains the same.
I have a question for you here :
Could you please confirm us if the switch is powering on or not if the unit is not powering on then you can try the below steps :
Try to use another power cable
Try another power source outlet
Try to hard reset the switch
If the above steps don't solve the issue then next step is RMA:
Please log a ticket with the below link so that we will help you to process RMA
If the switch is powering up then you can follow the below steps:
1>Compare the configuration between the working and non working unit and check if any configuration is missing after the power interruption.
This issue may happen when the Switch runs on the Routing code (SPR). The Switch should run on the Switching code (SPS) to avoid these issues for Lennar home users. If the Switch boots up on the other partition (Due to a power outage/power spike) which may be running on a ‘Routing Code’ results in causing this issue. To check the same please follow the below process.
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
show version
show flash
You can also follow the below link thread and follow the troubleshooting steps:
NOTE: Please confirm us if you are from Lennar Homes
Moving Forward If this issue is not resolved , Please log a ticket with the below link so that we will help you to process RMA
I hope this information helps you
Please feel free to leave us a message if any concerns
Note: Please feel free to mark the post as ACCEPTED SOLUTIONS if its addressed your query.
04-08-2024 07:27 AM
Hi Kahboom
Thank you for reaching us.
04-09-2024 06:53 AM
Hi @kahboom
Could you please update on the status of this issue?
Thank you again.
04-09-2024 07:02 AM
I am a Lennar homeowner.
Because of the extreme level of complexity to fix the issue and the inability to receive direct phone support, I have simply replaced the switch with another brand.
I wont buy another Ruckus product for home use as it is too complex for a layman without the assistance of a network specialist, and I wont buy another Lennar home. They left their customers hanging on this issue and I am considering filing a complaint with a consumer protection agency.
